bryan372002
s it acceptable to wire e-stop buttons in series in other words take 2 e-stop buttons and wire them in series to a single channel e-stop relay.
Thanks
Thanks
Thanks
Yes. Why do you think that it may be a problem?
Be careful of the wiring of E-stop buttons into a safety relay. Some relays have 'checking' circuits which use two sets of contacts on your stop button, others don't.
Some Safety Relays will allow you to wire them in parallel, (or a "cascade"); it's done when it's important to know WHICH e-stop was pushed. An example would be as follows:Now that this has been successfully asked and answered, I'm going to invade with a sidebar question.
Is there any other way to wire e-stops but in series? I've never done this or been involved with it, I'm just trying to work it out in my head. The machines I worked with at my last place of employement had over a dozen e-stops located all over the machine. Any one of them needed to shut the whole thing down. If they weren't all wired in series, how else would that get accomplished? A separate circuit for each button?
A machine with 3 e-stops, A, B and C plus 3 machine zones, 1, 2 and 3. If you hit A, it stops zones 1-3, but if you hit B, it only stops 2 and 3, and C only stops 3. The reason is, stopping the entire machine presents a greater danger than stopping only the zone where an immediate danger is present.
As a sidebar to this post, I am wondering where illuminated e-stop requirements are found...
I am trying to figure out if they now need to be lit under normal operation and off when and e-stop condition is present, or is it the other way around?
In our plant we have both examples, and I am trying to look for the regulation on this.
