E stop vs Spring return to center
W@ttson
USA
Hello,
I have a converyor belt. I have a spring return to center switch. To the left the conveyor belt goes one way, to the right it goes the other way. If I let go the conveyor belt stops because the switch springs back to the center off position.
This is on a control panel which control a bunch of different conveyors. Each conveyor has its own switch.
The control panel does not have an E stop.
I am thinking that the spring return to center is not enough to be compliant with NFPA 79 requirements.
Thoughts?
Hello,
Thoughts?
I don't know about NFPA 79, but anything I did with multiple motors in a process had an Estop. Everything stopped. Nothing I worked on would have created a bigger problem when they did stop.
Spring returns don't always return.
Viewing NFPA 79 is free online if you make an NFPA account.
is specifies what type of switches e-stops can be.
spring return switches do not qualify as an "e-stop"
Hello,
Thoughts?
Did your risk assessment process determine you needed an estop?
