Earth ground assembly
This is introducing a idea of mine for mobile, hybrid locomotive (vehicles) and marine vessels. The alternative to using the chassis for grounding is a large sealed metal block or tube sealed and isolated appropriately sized with a bus connecting the grounding and bonding conductors to works allowing fault protection and isolation of arch, flash, and spark potential between the combustion components and electrical components. The components of the combustion can still be grounded by the chasis to isolate fault paths as the electrical components fault path being to the ground block or tubes. Do you think that this idea will catch on.
I don't think it will catch on because it doesn't serve any real purpose. The chassis is a perfectly effective bonding conductor and return path.
