This should be an easy one. You are running some conduit in an existing building. One conduit has to go through a concrete wall. So you plug in your trusty drill motor at the nearest receptacle, crank it up and bear down on the wall. To your initial supprise, the incandescent light in the room gets brighter.
You are a little supprised, since you are used to seeing the lights dim when your power hungry drill fires up.
Why did the light get brighter?
Just use basic electrical theory to solve this. Don't overthink it, and assume your eyes can detect subtle changes in light level.
(I realize that it would be pretty easy to nit pick the solution I'm thinking of, and you guys can probably come up with a 100 reasons that the light wouldn't really get brighter. But I am just looking for one basic way the light would get brighter.)
