Easy way to determine hours of dust-to-dawn hours between dates for a given latitude?
Electric-Light
I am wondering if there is an app or a site that can let you enter latitude, start date and end date and provide cumulative dusk-to-dawn hour.
I would like to have an easier way to calculate cumulative dusk-to-dawn hours between dates to help with auditing a group of installed fixtures for conformance with LED degradation allowance specification at the given burning hour.
GoldDigger
Placerville, CA, USA
Retired PV System Designer
I would be concerned that the dusk to dawn time based solely on sunset/sunrise will not necessarily accurately represent the on time of the lighting.
On the other hand a member here produces photocell drop-in replacements that use GPS and astronomical data to control on/off times.
That is totally predictable and I would not be surprised if his company either has or could easily provide the kind of application you are looking for.
ggunn
Austin, TX, USA
This would likely do what you want:
http://solardat.uoregon.edu/SunChartProgram.html
Oh, you said cumulative. Never mind.
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
Some of the Intermatic Timers that are astronomical have data on that. Some come on a spec/instruction sheet and also have it in the timer program. You put in the info for your area and it sets the timer accordingly for D>D.
You might look on their website and get a chart. Probably have to do some math though for the cumulative part.
junkhound
Renton, WA
EE, power electronics specialty
search for insolation tables (yes correct spelling) on solar sites - you will get everything you need, including dark cloudy day data, etc.
