Never saw an Eaton, or any brand, where the breaker is both a PON, and have a pigtail. It's usually one or the other.The DF has the pigtail neutral, presumably in addition to the plug on neutral (PON).
Date: Fri, Aug 30, 2024 at 11:14 AM
Subject: Re: Blank specification
Hi Bryce,
Functionally they are same.
BRP120DF - Updated version
BRP120A1CS - this comes in clamshell packaging.
I found out that some appliance model numbers are unique for stores, so price comparisons are futile.Literally the packaging? That's nonsense.
That is the case here, the breaker package and numbers are even different from big blue to the big orange. Both using the clam shell package, but the box type are usually found just in supply house, also found that in online stores you could randomly get either. Found this when went to return an unused breaker to the big box, when they scanned the product they said it wasn't theirs it must be from the other big box, (a job that had to get multiple so because of limited stock in one store went to another).I found out that some appliance model numbers are unique for stores, so price comparisons are futile.
The model # on the breaker should be identical. I believe all breaker manufacturer's have a separate part # for the CS packaging to distinguish between what goes to retail and what goes to suppliers. Lutron, Legrand, etc.. do the same thing.What do the actual breakers say on them?
Often just a suffix at end of same catalog number to designate type of packaging.The model # on the breaker should be identical. I believe all breaker manufacturer's have a separate part # for the CS packaging to distinguish between what goes to retail and what goes to suppliers. Lutron, Legrand, etc.. do the same thing.
