SHEA 31979
- BROOKLYN, NEW YORK
I have a 100amp main breaker panel that is being fed from a 100amp breaker disconnect. When I powered everything up stabs 1, 7, 15, 16, 18 & 20 I am not getting any power. I am wondering if anyone has had this problem before. When I tested the feed coming into the sub panel, I got the correct readings for line to line, line to neutral and line to ground. I am thinking the weld in the back might be shotty and will just have to replace the guts. Thank you for any and all assistance.
