EC&M Magazine, Cookie Tin Light Fix
jmellc
Durham, NC
Facility Maintenance Tech. Licensed Electrician
November issue of EC&M, Illustrated Catastrophes, page 23. Someone put a cookie tin over a ceiling box, mounted a pull chain light to the lid, threaded leads through & pigtailed to ceiling wiring. Then secured lid to tin with side screws.
Naturally, as the writer points out, no grounding & sharp edges. Not UL approved. I have to laugh at it but sad thing is, I see much worse than this every day. If I saw this in some houses I would think "at least someone tried to fix it with what he had available. I see open fixtures hanging from wires, sometimes, just bare sockets hanging down. Receptacles hanging out of walls & being used, open lights & receptacles hanging in muddy crawl spaces, etc. I see space heater receptacles tapped from range outlets, with 14-2 NM. Range outlet fused at 40-60 amps. Open panels are nothing unusual either. Most customers will not or cannot pay to fix it all either. Will only pay to fix the 1 or 2 items out at the time.
Welcome to residential work. If I ever get a larger base of commercial customers, I would love to make residential a distant memory.
Here is the pic and here is the webpage talked about.
I'm not defending it but, I like it. :D
Roger
We have quite a few business's around here (mostly BBQ restaurants) that have porcelain lamp holders screwed to the underside of a wash tub as a light fixture hanging from a chain. I wish I had a picture, but alas, no! Most of them are not grounded, and a couple of strips of electrical tape is put across the terminals to keep it from shorting out.:roll:
Do no expect commercial customers to be any less creative.
Oh if they where a real mechanic they should have installed it up right and tapped the lid(better). At least they could enjoy the illustration more... My Father made a sharper looking lamp with the animal crackers tin! Come on pickers! :D
I disagree. You would just see the plain old unpainted bottom of the can, then.
Better to seek designs that have no 'right side up'. I would also recommend losing the label. The label is what makes it tacky looking.
Yes, I have seen some jacklegging in commercial but not nearly as much as resi. I used to work commercial with former employers that did nearly all commercial.
Some of the worst I've seen was in nursing homes, one example was 2/prong when it was built, later changed to 3/prong receps with nothing connected to ground prong (like we often see it dwellings, but here there were hundreds of them).
