JimmysLimeade
EE Student & PV Design
- Utah
- PV Design
Not sure if the title makes sense here but I am designing a project in Illinois that needs an EE stamp. They have redlined a few of our plans stating the wire size needs to be sized up because we have to use the 60C column in 310.15 for conductor ampacity. Here are a few of the different situations where we have this issue:
And when I asked him about it, all he said was this "See NEC 110.14(C)(1). You can only use the 90 degree C for derating calculations. Since your calculation came out higher than the 60 degree C column, you have to use the 60 degree column for the ampacity."
Could someone help explain this to me because I don't understand how this works. I might be missing some info so if you need extra clarification let me know.
And when I asked him about it, all he said was this "See NEC 110.14(C)(1). You can only use the 90 degree C for derating calculations. Since your calculation came out higher than the 60 degree C column, you have to use the 60 degree column for the ampacity."Could someone help explain this to me because I don't understand how this works. I might be missing some info so if you need extra clarification let me know.
