Re: Effectively grounded Building Steel
In a typical steel frame building the steel will be bonded to the ground bus at the main service, this with the fact that the beams are bolted to anchor bolts in the cement footing should make the steel "effectively grounded".
But as already stated it can go beyond that, I just started a new job Cadwelding #2 bare to rebar's in the footings, foundation walls, when the floor goes in we will pick up the rebar in that too, also about 50% of the steel columns will have #2 cadwelded to them at the base
All these #2 bare Cadweld to a 4/0 Bare "ground ring" around the building and to about a dozen 10' x 3/4" ground rods, with 2, 4/0 T-Taps off of the ring back to the service gear.
[ March 21, 2003, 05:54 PM: Message edited by: iwire ]
