jeff43222
- Minneapolis, Minnesota
I have a customer who currently has overhead service and wants it moved underground because the service drop wires are in the way of a planned sports court in his back yard. The existing run between the meter and the panel runs through the slab in the walkout basement to the panelboard deep inside. Most of the basement is finished.
My plan is to install the underground service and an outside disconnect switch, which I would then connect to the existing wires/conduit running through the slab. But I'm pretty sure there is no EGC inside the conduit (1-1/4" RGS/IMC). My reading of 250.134(A) makes me think that the conduit can serve as the EGC of the panelboard. I usually run a separate EGC, but in this case it's not too feasible.
Or am I missing something?
