reyamkram
- Hanover park, il
When I was working in a 480 volt 3 phase panel, no neutral just straight 480 volt 3 phase, I found, some EGC connected to the neutral bar, this is a sub panel,
no connection from the neutral bar to the panel, and the neutral bar was connected to a ground rod, I did remove the EGC and install them on the ground bar that
is connected to frame of the panel. what type of electrical hazard could that be, if there was a ground fault. we do have the pipe for a ground fault path, if the pipe did not come loss, or is not tight at the connection points. This is and old industrial building and that is very possible. What are some thoughts on this matter.
Thank you, for any and all information.
