chris kennedy
- Miami Fla.
- 60 yr old tool twisting electrician
I got a final at a restaurant in a county south of here today. The inspector told be to lose the GFCI for the phone board. This is in the kitchen on the wall at an elevation of 8' aff. I pointed out that there is no exception for elevation and was told that since the burg wall wart was plugged in there I had to install non-gfci devices here. I'm not going into how bizarre the conversation got after that, but I intend to reinstall the gfci on my next trip down.
I have a problem defeating GFCI protection where the code clearly states it shall be installed. My question to you is would you worry about it or leave the non-gfi recs? As stated, this is high above routers and such mounted on FRP laminated plywood.
Thanks
Brain dead and burned out.
Thanks
