090122-1808 EST
MD88:
A 485 system is a balanced line half-duplex type. Probably means you may require 3 wires. Two signal wires, preferably twisted, and a common reference path connection.
In a 485 system you can only send data in one direction at a time, and there has to be some means in the communication protocol to determine who is the sender. In a 422 system between two points you can have simultaneous transmission in both directions.
A major problem that is usually not understood is the ground reference conductor, and difference voltages between different ports connected to the 485 or 422 cable. A system using electrical isolation in or external to the 485 (422) interface can greatly reduce problems from these ground voltage problems.
