EIT exam prep help
youngengr
New member
New York City
I am having a hard time passing the EIT. I have studied on my own (didnt work), and taken a prep course (helped some but still didnt pass). Does anyone have any suggestions as to what reference manuels I should be using to study to finally get this exam under my belt?
http://ppi2pass.com/ppi/PPIShop?ct=FEEXAM
Follow that link. That is the stuff I used when I took the F.E. I passed it the first time, but then I may be way smarter than you. :D
:D I'm kidding. :D You'll get a lot of that here. Welcome to the forum.
I overstudied for the FE roughly a year and a few months ago. Best advice in retrospect is to get your hands on the reference booklet, with all the equations and formulas. (a copy from your previous exam is just fine - doesn't have to be the most recent)
If you familiarize yourself with EVERYTHING in that booklet, you will be more than prepared. By familiarize I mean you should be able to look at any equation/fact/table in that book, and know what kind of problem it would show up in.
Go through that booklet item by item. If you know what something is for and how to use it, check it off and move on. If you aren't sure, be honest with yourself and mark it to look up in your own/buddies' notes/texts. When you look something up, find an example problem or two and use it to burn it back into your recent memory.
For reference I took both "general" sessions (all-around) as that matched my education in architectural engineering the best. I'd taken courses that covered most of the material on a basic level. There were a few subjects I had zero-to-little experience in (programming diagrams/environmental engineering...), and quite a few more "weak subjects" (chemistry/economics), but after going through once to nail the easy/solveable problems, coming back to the tricky stuff I was able to get an answer for probably 80% of the questions I gave a pass on the first go-around.
Those tricky problems all came down to recognizing a concept/formula that was in the booklet and knowing it was there to look up.
BIG SUGGESTION: retake the test at your next opportunity. the stuff you've been studying and the advantage you have now from taking the test once will sieve quickly from your memory and you don't want to put your re-take off.
Are you taking the Electrical portion for the 2nd half of the exam?
When I took the exam, on the 2nd portion I took the electrical and I saw a lot of problems dealing with BJT and mosfets...I'd say anything you'd learn in a basic circuits class is fair game here.
Some logic problems as well.
I took this right out of college, so I had the electrical portion down pretty good...I bought a Kaplan study guide and tried to make sense of the thermo/civil/structural stuff that I had no idea on and that helped greatly.
FWIW, I'd take the electrical portion instead of the "general" on the 2nd part...
