paul renshaw
- Cordova, Maryland
Should the ground rods and conductor supplying them on an electric fence be bonded to the system GEC? There is a structure built that has a sub panel mounted on it and also the electric fence charger equipment. The charger is plugged into a GFI fed from the panel. The sub panel is fed with four wire (1 ph 120/240) with neutral and ground split, and 2 rods for earth connection. The fence charger energizes 2 of the four strands at + and the other two are - which are also connected to earth by rods. Wouldn't there be a potential difference between the two if they are not connected (bonded)?
