davedottcom
I need to install (2) 20 amp circuits for 2 "back to back" electric fireplaces built into the adjoining wall of 2 rooms. One room is a bedroom and the other is not. The outlets will be located "Inside the framing" between the two rooms. They will only be accesible if you remove the fireplace (for service). I'm trying to determine if either outlet needs to be AFCI protected. Personally, I don't think they are considered to be "In" the bedroom.
Any thoughts on this?
Dave
Dave
