TheWantonElectrician
- Madison, WI
- Master Electrician (Residential and small-scale commercial)
I have a customer that will be replacing their electric fireplace insert. I don't believe there is any grounding in the entire house.
1) Does replacing the current three-prong outlet with a GFCI outlet provide the device with added protection? Seems like an obvious, yes.
2) If none of the circuits have a ground wire, is there a point to adding a grounding system at the panel?
3) If all breakers in a panel were switched to GFCI-breakers, is there a point to having a grounding system?
