electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Guy has 2 zones/circuits of electric floor heating cable. 240V, 3500 watts each. I installed the thermostats but nothing else. The cables had the squauk boxes on them with no alarms. I put in the thermostats and fired them up, tested draw which was about 3500 watts and all seemed good. They were on for probably a couple hours until I left. He calls me next morning, says BOTH t-stats are showing ground fault error. Any ideas? I haven't gotten back to do any resistance checks. Of course now I'm all paranoid I did something wrong...... I triple checked with them it was supposed to be 240, and they said sposta be 16 watts per foot and they used a thousand foot roll for each circuit, so that checks out. What if i didn't connect the temp sensor correctly and it overheated and failed? Is that a thing?
