dnbob
- Rochester, MN
We are wiring a furnace with a 24 KW 208 single phase heat strip, and a separate 20 amp 208 volt circuit for the blower motor. The heat strip is not connected to the blower motor/circuit board.
Will I have to install a disconnect within sight for the electric heat strip at the furnace, along with a separate 20 amp disconnect for the blower/board, grouped per 424.19?
I haven't wired one for a while, but thought we used to be able to use a lockoff for the electric heat portion, but I don't see that as an option for this install.
