DTHUDEE
- LARKSVILLE, PA.
CAN YOU RUN 14/3 FROM A PANEL USING A 2P-15 AMP BREAKER TO A 240 LINE VOLTAGE STAT TO OPERATE A 750 WATT 3 FT PIECE OF 240 VOLT BASEBOARD HEAT; THEN RUN 14/2 FROM THE STAT WALL BOX, USING THE NEUTRAL AND EITHER LINE SIDE WIRE TO POWER 2 HALL WAY RECPTS.? iF NOT, WHERE SPECIFICALLY IN THE CODE DOES IT SAY THIS IS NOT PERMISSIBLE?
