electric heat calculations
shelco
Does any one know of a web site or other source to calculate what is required for electric baseboard heat per size of the room?
Obviously other factors as well.
I have a customer that wants to tear out the LP gas heater and put in baseboards.
Re: electric heat calculations
I have always heard the 10VA per sq. ft. also.
Of course a R-O-T based on cubic feet does make more sense.
10 VA per sq. ft. = 1.25 VA per cu. ft. in a room with an 8' ceiling. I agree with kiloamp that the cu. ft. calculation makes more sense, and I too was taught 10 VA per sq. ft.
It also depends on your insulation and how cold it will get.
Thanks for the in put.
I really don't know why they want to replace LP for electric. I suggested to simply change out the old gas furnacce with a new high efficiency, but she still wants electric.
Maybe because LP here is about $2.79 to 2.89 per gal. and electricity is $.04 per KWH.
"I was taught that one cord of wood split, stacked and dried per month"
just remember that if done properly firewood can warm you 2 or 3 times,
once when cutting and loading,
then when splitting and stacking
then again when burning it
Better stop now , it's getting warm .....
The problem, of course, is that I do the first two steps in the summer, when I don't need to be kept warm. :D
The voice of experience has spoken and a did a fine job doing it too
