wireman3736
- Vermont/Mass.
I have a customer who is complaining about the sound coming from the electric heat control panel. The panel is next to a family room and the buzzing is annoying as I noticed when I went there today. I want to replace the contactors with electronic relays, the existing contactors are magnetic 120v coil with 30 amp 240 volt contacts. All the heat circuits are under 20 amps. My concern would be heat building up in the electronic relay even though there rated for 40 amp, any helpful information would be appreciated, Here is the relay I was thinking of using for replacement except I would be using a 2 pole if they make them. http://shop.vetcosurplus.com/catalog/product_info.php?products_id=8844
Thanks Stan
Thanks Stan
