Stevenfyeager
- United States, Indiana
- electrical contractor
I re wired a modular home with two 60 amp breakers to a new heat pump furnace. The only thing the inspector said was "confirm breaker size on furnace" I put two 60 amp breakers like the original panel had. He said he never sees a modular home furnace bigger than 15 kw which would be one 60 and one 30. He told me to call the HVAC man, and I will probably need to switch one of the 60 s for a 30. ( he said a 18 kw would be two 60 s) I went back and looked at the furnace, it has two 60 amp breakers on the furnace and the label says 14.5 kw. I called the HVAC man who installed it, he said I did it correctly. But when I call the inspector Monday, I don't know if I am confident I did it correctly. Help. Thanks !
