tom baker First Chief Moderator & NEC Expert Staff member Location Bremerton, Washington Occupation Master Electrician Jun 3, 2005 #2 Re: Electric heat Its based on the heat loss and lowest outside air temp. in your area. Heat loss is determined by insulation, windows and doors.
rcarroll Senior Member Location Fort Collins, Colorado Jun 3, 2005 #3 Re: Electric heat For electric baseboard, I used to figure 8 to 10 watts per sq. foot.
mdshunk Senior Member Location Right here. Jun 3, 2005 #4 Re: Electric heat I used to always use the "one watt per cubic foot" rule of thumb, which worked for me for over 20 years. Since learning more about HVAC, I run a quick ACCA "Manual J" calculation on the computer to get the real numbers per room.
George Stolz Moderator Staff member Location Windsor, CO NEC: 2017 Occupation Service Manager Jun 4, 2005 #5 Re: Electric heat I'm at a higher elevation than mdshunk, I think. At around 5000', we use 1.25 Watts per cubic foot. Up in the mountains, it's more like 1.5 Watts per cubic foot. I prefer the cubic foot method over square footage, because it accounts for odd ceilings a little better.
