Andres Arias
PV Solar engineer
- New York
- Electrical Engineer
Good morning dear collegues.
When we are going to install a PV system in a residential electrical service, we often find that the electric meter is installed inside. As per NEC, the electric meter should be installed outside considering the height and the clearance. Does the electric meter have to be relocated outside (required) of the house when it is found inside? Is this related with an electrical service upgrade required in the house? When is electric meter relocation certainly required? Thank you in advance.
