ptonsparky
Tom
- EC - retired
I have a couple hydraulic motors that I would like to start/stop via a solenoid. What basic info do I need to know about the hydraulics. GPM, pressure? A link for reading?
Are you looking to have the slam on/off that a solenoid will provide or would it work just as well if the on/off action was more like a ball valve? (I was thinking an electrically actuated ball valve).
I understand that, and assumed there would be a pressure relief valve set to return product back to the tank in the event the pump was dead heading. At least that's the way I always did it.You can't just block off the line. If you do you will raise the line pressure up to the set point of the relief valve and likely overheat the hydrulic fluid. Or if there are other motors on the same hydrulic circuit they will speed up.
Keep in mind that hydrulic pumps are 'positive displacement pumps' the fluid has to flow or the pump will stall the electric motor driving it.
When I worked on hydraulics the valve used would simply reroute the flow back to the supply tank without raising the pressure to the point of opening the relief.
I do this for a living for some local organizations ... and most of the answers so far are right ... in SOME cases. Post more info, or PM me and I'll help you define your needs. If the system is designed for "closed center" loads, valving designed for "open center" loads won't work very well. Similarly, if the system is designed for "open center" loads, valving designed for "closed center" loads won't work very well.I have a couple hydraulic motors that I would like to start/stop via a solenoid. What basic info do I need to know about the hydraulics. GPM, pressure? A link for reading?
