sparks1
- Massachusetts
Appliance technician is having a problem with the range voltage. He says the range won't heat up because the reading at the terminals is A-Grd 220v, A-B 220v and N-B nothing. It's a new range plugged into an existing 3-wire outlet. I've checked all the connections & bonding jumper in place ok. When the range load is unplugged the voltage at the outlet is normal and it reads A-B 220V,A-Grd 120v, B-Grd 120v. I've checked everything out at the main panel.
What's going on?
Is there a problem with the range?
I suspect it might be a problem with the utility transformer. Anyone have this problem before?
[ September 28, 2005, 10:23 PM: Message edited by: sparks1 ]
What's going on?
