bigduvid
- Cleveland, Ohio USA
I had a peculiar situation yesterday. The house was built in the 30's - 40's. It has knob and tube wiring, wood lath-plaster walls.
The customer complaint was that when turning on the kitchen light, they received a shock. We pulled the switch apart and found that the system switched the hot's, When the light switch was off, and we touched the box with a two wire tester, it tester light glowed lightly, an indication of leaking electricity. There was continuity between the hot wire and the box. When turning on the switch, the continuity disappeared.
We confirmed another switch on the same circuit.
There were no bare wires touching the box. Any ideas what might be the cause or what we should be looking at?
