Is there no other circuitry, like a DC-to_DC power supply?Use theory how does the charge from a battery source using a capacitor play out to reach enough charge to kill mice?
Ok that's the intent, now show the math (theory)How much do you think it takes to stop a heart?
A: not as much as you might think. Only around100mA to start to have an effect, 200mA to put it solidly into fibrilation. The capacitor just boosts the votlage to get to a point of overcoming the resistances in the mouse skin and hair.
Calculate using 12VDC as the source
A capacitor can't "boost" voltage without some help from other circuitry.
-Hal
IF you Youtube "electric mouse traps" there are many videos. Popular sources seem to be those electric bug racket thingies and stun guns. 12 Volts is not going to cut it. A bunch also seem to have a battery and a capacitor as the electric source, but I agree with Hal just a capacitor and battery isnt going to raise the voltage so not sure what the deal is there. Must be other components that are not visible.
The voltage in the equipment is probably derived the same way that xenon camera flash units get high voltage DC from low voltage batteries. Those circuits also do not need to deliver current continuously to the HV circuit and they can take awhile to charge the HV capacitor. On most of them you could hear the audio frequency of the relaxation oscillator that drives the step up circuit. Rather than a capacitive voltage multiplier they used a coil circuit with a high transformation ratio, somewhat similar to the old automotive spark coils.But where are you getting the 20kV from?
-Hal
Yes, they used a flyback converter that has a two winding inductor that is very much like an ignition coil. When the voltage on the HV capacitor is low initially, it takes longer to discharge the energy stored in the inductor over to the cap during each cycle because dI/dt = V(t) / L, where dI/dt is the rate of change of the current. But then as the cap voltage rises the coil discharge time reduces and so the converter switching frequency increases. Eventually the duration of each cycle (and therefore the switching frequency) becomes limited by the time it takes to charge the inductor from the battery voltage.The voltage in the equipment is probably derived the same way that xenon camera flash units get high voltage DC from low voltage batteries. Those circuits also do not need to deliver current continuously to the HV circuit and they can take awhile to charge the HV capacitor. On most of them you could hear the audio frequency of the relaxation oscillator that drives the step up circuit. Rather than a capacitive voltage multiplier they used a coil circuit with a high transformation ratio, somewhat similar to the old automotive spark coils.
Suppose you charge two capacitors in parallel from the same battery. Then you disconnect them and rearrange them so they are in series. You will trade Farads for Volts, and increase the voltage across the combination of components. This is one way of increasing the voltage of a DC power source for a static discharge. The rearranging is accomplished with components such as transistors, to switch the circuit path among the capacitors as it switches from parallel to series.
With AC, you can build voltage multipliers ...
