In an industrial plant I want to use an electric water heater (208V, 3-phase, 4KW) to supply hot water in a closed loop piping system. Other words no faucets, hot water keeps circulating around and around to keep something from freezing. A guy in the plant says a electric water heater can not be used for this application. I've read NEC article 422 - Appliances and I don't see where it can't be used. Is there somewhere else I should be looking? This project is in MN btw.
Thanks,
Thanks,
