Is it legal to run romex to water heater without having any type of conduit protecting it. The water heater is mounted in the attic. I know you have to have a disconnecting means. But am not sure about the romex unproteceted.
Thanks
Code wise you are fine with the proper support already mentioned.
For the record, this is how residential water heaters are usually wired in my area, regardless of location in the dwelling. I have yet to see a disconnect on one either (when a disconnect is required.)![]()
334.15 defines how NM is to be installed for exposed work. b A piece of NM "floating: and not secured to or following a building finsih or on runnimng boards and no protected from physical damage does not meet the requiremts of 334.15. Nor does it meet the requirements of 334.30(B) for unsupported cables.I can't see the specific prohibition. Cite me on it and make it stick. :-?:smile:
I'm thinking 422.31(B).:smile:
Cited often, has always "stuck"
Well at least the wirenuts are TAPED!!!!!![]()
