jumper
- 3 Hr 2 Min from Winged Horses
I pulled these posts from another thread to ask my own question. The thread was on parallel conductors.
Why does the type of raceway affect the ampacity and/or resistance of conductors?
Like when using Table 9, Chapter 9. You have columns for steel, PVC, and AL raceways. The numbers for each are the same until you get up to larger sizes like #1 or such.
310.10(H)(3) says: (3) Separate Cables or Raceways.
Where run in separate cables or raceways, the cables or raceways with conductors
shall have the same number of conductors and shall have
the same electrical characteristics.
What actually happens if they do not? For example, 2 parallel sets - 1 in PVC and 1 in EMT.
I understand length, insulation, size, of conductors but how does the raceway type come into play?
Certainly the raceway type must be the same, IMHO.
Why? I am not being a smart aleck. Real question.
The physical aspects of the sets must be identical.
Electrically that means at a bare minimum that the number of conductors per raceway must match, and the ferrous/non-ferrous nature of the raceway must match.
