rocketscientist15220
New member
Hi,
I am doing an electrical area classification of a heater at a refinery. I am concerned because the client specification calls on us to unclassify not only the stack but also the entire burner. Is this an acceptable practice? Of course, the inside of the furnace will be unclassified because anything inside will burn. Unclassifying the burner does not make sense because I've seen gas leaks. Normally, API 500 allows a 15 ft length and a 25 radius around sources. Our client has also asked us to focus only on primary sources. We are to ignore flanges and hand valves because operators will detect such leaks. All of this seems a little loose. I was wondering what others are doing about electrical classification.
