I am reviewing a public agency project were a replacement air handling unit (AHU) has been installed in an existing mechanical room. The mechanical room has no other equipment except the 120V AHU control panel and a water heater. The AHU is rated 480V and has two VFDs and a disconnect ahead of the VFDs. The clearances for the VFDs and disconnect are between 30"-40".
Customer recommended solution: The customer would like to relocate the disconnect such that the clearance is greater than 42" (but not 30" wide), and post signs that the electrical equipment cannot be opened or maintained unless deenergized, and the work can only be performed by qualified personnel. A sign can be posted at each entrance door and on each disconnect/VFD.
Any recommendations concerning the suggested solution?
