Hello all! I am a simple homeowner and have a question regarding the electrical connection for a sump pump. The sump pump is just outside the foundation/crawlspace installed inside a plastic meter box. The drain hose and power cord snake through a hole in the foundation and into the crawlspace.
The power cord is plugged into a standard extension cord which is snaking across the house and plugged into a GFCI outlet under the master bath whirlpool tub. The tub and the extension cord/sump pump are the only 2 things on this circuit.
My builder has said that this is pretty standard and that by having the sump on the GFCI with only the tub, if we ever have a problem with the sump there can only be 2 possible issues. I'm a bit uncomfortable with this arrangement since it seems like it was thrown together. The builder has said that he will run another electric line and a new outlet but then started talking about having to cut a hole in the kitchen wall to install a switch for the pump??? It's not on a switch now???
My question: is there anything in the NEC regarding the use of an extension cord as a permanent power solution for a sump pump, or really any application at all? I live in Chattanooga, TN and have been unable to get in touch with anyone in the county inspector's office. If anyone can provide any references or solutions to this situation, I am all ears. I certainly want to have something to take to the builder directly one way or the other.
Thanks so much in advance. Sorry this ended up being so long. Please email or post if you have questions or need clarification.
