Jules
New member
- Asheville NC USA
Ok had a small panel change in a short term rental. Cottage about the size of a hotel room. Bed room, wet bar and fridg, bath room. Feeder 100 amp underground from main house.
The panel needed a change out, corrosion and generally a weak/loose buss. Circuits consist of general 120 lighting, a 120 water heater and two 240V. Wall heater and hot tub.
Lights are dim and flicker and one phase of main feeder reads around 80v. This corrects itself if the 240 heater is on and returns when off. This is what was happening with the old panel and really felt the new panel wouldn't correct it but it was a start and needed replacement at any rate.
so once again heater on all is fine heater off things are wierd. Turn heater breaker off problem so I don't see it being a faulty heater.
