Electrical designer
mbresit
Air Tubing in electrical cable track
I need to use continuous flex cable one 24vdc ,one 480vdc (motor control) and one air tube in the same cable track. Reason : not space.
I don't know where i can find information about that in the NEC
The article 300.8 don't specify nothing about cable track.
I have seen some robots with mixet electrical cable with air. Are thie rong?
Thank You mbresit
by cable track do you mean a movable track to contain cables, folding and unfolding with the movement of the machine? Then I believe its ok because the conductors are in flex conduit or cord and the air line is simply run near the electric..imo
not sure if it is rong or not. could you provide more information ? Is this a vehicle, mining equipment ?
I'm not sure what you mean by a cable track either. Do you mean a cable tray, or ladder tray?
Just because they can run everything together in a piece of equipment (like a robot for example) doesn't mean its OK for premisis wiring systems. Two totally different animals.
steve
electrical dessigner
Yes, i use the flexing cable track ( cable carrier Igus whit flixible cable + air pipe) like in your pic M. Ibew501.
Do You know in witch acticle from NEC i can find information.
Yes this tipe off cable track (cable carrir ) i us.
Do You know in witch article off NEC i can find information about that?
Thank You
