Ragin Cajun HI
- Louisiana
- Home Inspector
Can someone give me just clarification? Is a electrical disconnect required for an exterior mounted gas tankless water heater? Thanks
Why is a builder telling the electrcian how to do their job? Does your state have no licensing? Does the builder know the NEC better than the electrician?You asked this same question in August.
Disconnect
On gas tankless water heater, what is the Requirement for electrical disconnect? Local national builder is having electrician hardwire with no electrical disconnect In sight of the appliance. Local jurisdiction, inspector stated, that's since amp draw was minimum an electrical disconnect...forums.mikeholt.com
It's required so call it out as a defect and let them sort it out. The fact that they "don't enforce that particular code" is not for you to decide.It's basically the code enforcement not enforcing the code ,,i had a call with the code guy and cite the code to him and his response is they don't enfore that particular code . OK as a HI I am putting it in my report yall go figure it out , Gezz
IMO, yes. It's an appliance.Can’t a breaker lock work?
