Andre01
New member
- Tampa, FL USA
Mike,
We are an OEM of industrial x-ray equipment and will be designing a new platform of machines. Since our x-ray cabinet houses the electrical/electronic equipment we have an access to this equipment via an access door. There is no separate enclosure to house the electrical/electronics. Per NFPA 70 or 79 or UL508A, are we mandated to mount our electrical disconnect (rotary style, non fusable) switch handle on the access door with switch body mounted on a panel in the enclosure? Can we still comply and mount the electrical disconnect on a side wall of the cabinet as long as the access door has closures that require a special tool to open? Does this still fall into compliance? Thanks
