Electrical fields on AC wiring
090607-1255 EST
fields5491:
Your suggestion of the 75 Hz signal that you think you detected might be submarine communication is virtually nil.
See
http://en.wikipedia.org/wiki/Communication_with_submarines#Extremely_low_frequency
Here it references 76 Hz for the US and 82 Hz for the Soviet's. The resulting signal level at a receiver is very small. It will require a very narrow band receiver with a very low noise level and probably some form of correlation detection to receive this signal. No way will your instrument detect this signal unless you are somewhere near the transmitter.
Take your instrument out in the middle of nowhere. What frequencies and signal levels do you measure? Anything at 45, 60, 75 and 82 Hz? How about up to the 100th harmonic of 60 Hz? Next in a screen room apply a 60 Hz sine wave from a clean signal generator. What frequencies do you see?
Your reference to Graham-Stetzer Research really took me nowhere relative to a 75 Hz signal because I did not know what paper to look at.
Although uncorrelated with 75 Hz I did read through most of "Testimony of Dave Stetzer in Lawsuit Filed on Behalf of Michigan Attorney General" which relates to stray voltage and drifts off at the end to other human interaction.
He provided very little numerical data, mostly qualitative statements, and toward the end more like testimonials.
Using a 200% neutral will not eliminate ground currents, however, it should reduce the ground currents. Bad splices may be even more of a factor. He provided no quantitative data to compare the ground currents or stray voltages in the farm areas where the one Wisconsin power company reduced the number of grounding points and went to the larger neutral. If substantial currents existed on the farms what were their magnitudes and how much were they reduced by the distribution system change?
could be a form of Schumann resonance http://en.wikipedia.org/wiki/Schumann_resonance
being imposed upon power lines, I have picked up on many weird signals that seem to be coming from the POCO's maybe for remote metering, or power line switch gear monitoring of some sort, these have interfered with tracing live lines with my tracer unit as they drown out the transmitter signal, but they seem to be of a higher order in frequency, so might not be the same thing unless a lower frequency modulation is imposed upon the center carrier? communication has been done on power lines for quit awhile, and now they are doing experiments with sending the Internet over it.
just a thought
090607-1945 EST
hurk27:
Your link did not work. However, I got to the site thru Google and the Wikipedia discussion was very interesting. Thanks.
sorry about the link, tried to get it to show up as just the name.
here is another link that shows a bit more:
http://www.iihr.uiowa.edu/projects/schumann/Index.html
This subject was in our studies when I was at University of Florida Gainesville studying about lightning, and Earth as a electrical ground, which was a connected study of communication electronics from Mid Florida Tech in Orlando.
And look at me now, just an electrican:rolleyes:
Spurious
Spurious
I don't remember what they are called, but odd lobes of apparent signal can be caused by the Fourier transform being used and the sample rate. They are not real but the mathematical process causes them to appear.
090611-1859 EST
The sampling rate of the data must be high relative to the bandwidth of the data or there will be lots of strange results.
Back on this once again. Lots of hypothesi on why this must be an artifact.
Let me ask this, if this was an artifact would the volts/meter readings be expected to increase as the probe was moved closer to the wiring? And the v/m decrease as the probe was moved away from the wiring, to the point that the signal disappears? This a consistant repeatable phenomena.
Another question. Does anyone know of a specialist who has real-world information on health effects of long term electrical field exposure, frequency specific? This is a shot in the dark, but would appreciate any leads.
I have seen this effect on digital oscilloscopes, more so in their early days when the sampling rates were not as good.
The term used to describe it is "aliasing" I think.
