Re: electrical gate operators
It is not possible to offer a solution (notwithstanding the installer?s proposed solution of installing lots of large ground rods), without first understanding the nature of the problem. What are the gates doing that they should not be doing (or not doing that they should do)? Also, can you give some details of the type of equipment that operates the gates? For example, are they ?pay as you enter? coin-operated gates? Are there pressure sensors in the pavement that automatically open the gate whenever a car approaches? Are there keypads that permit entry when the right code is punched in? Is the problem with the control system (i.e., that permits or forbids entry) or with the gate motor operators (i.e., that move the gate from the closed to the open position)?
