1st the details
15,000 sq ft. building
1/2 offices 1/2 shop
New building in a new industrial park.
120/208 3ph 200 amp service
QO Panel
Here's the problem/ problemssssssssss.
1. if you plug a saw into any of the outlets within a 150' of the panel the saw instantly trips the breaker. If you plug a 100' ext cord into the outlets, and then run the saw, it won't trip the breaker.
Amp probe shows 10 amps (+ or -) at start up for the saw. Volt drop to 116 volts +/-.
Nothing out of the ordinary..............
2. Breakers keep tripping for no reason. 1 row of L-bay lights tripped yesterday ( 4 lighs per circuit 120v, 14 amps on the amp probe, no VD)
The air compressor trips, the pressure washer trips, the office lights trip, some of the circuits barely even show up on the amprobe.
It doesn't matter what ph there on.
I checked all of our connectios in the panel, i've put loads on the service to check for VD I've checked amps.
I give up!!!!
It has to be on the utility company's end!! Right??? Nuetral problems??
Or is it a ghost.
QO Panel
I give up!!!!
Or is it a ghost.
