Electrical Inspector
Does the feeder have correct over current protection?
Is the feeder over current protection also providing over current protection for the transformer?
You can tap the secondary of a transformer to supply two different panels.
You would provide over-current protraction for the secondary tap, secondary tap rules,usually at the load end
as david pointed out, not near enough info to make a call.
If you take one step back and look ahead of the transfer switch, what protection will be
in place for the transformer with the switch in each mode ?
You need to look at Art 450.3 and 240.21(C) for more details.
