bandylb18
Industrial installation, utility receptacles w/three recepts. on 20A - 120V circuit, furthest distance to receptacle approx. 300', feed is #10AWG THHN. Using Art.210.23(A)(1) as standard to calculate voltage drop, i.e. code allows use of 16 amps of a 20A ckt. and figuring 80% of that which is 12.8A shows #10 to be too small a wire due to voltage drop. Is this a valid calculation, assuming 12.8 amps as a load to be anticipated? In an industrial setting, would you use the 180W standard for residential or commercial offices to figure utility receptacle load? The setting is a gas compressor station with five nine thousand horsepower compressors. Utility receptacles would be used by maintenance.
Let me know what you think.
