fandi
- Los Angeles
- Electrical Engineer
Hello All,
It's a change of use of an existing facility from a hotel to one-bedroom apartment (the bathroom is inside the bedroom).
Receptacles in different rooms were being shared the same circuits and now are being shared by (3) different units.
Same with bathroom circuits are now being shared by (2) different unit bathrooms.
I even see one existing circuit now feeds (2) different unit lights AND a common elevator light.
Traditional load calculations in 2020 NEC Article 220 don't apply because the units share same receptacle circuits and lighting circuits. If each unit is fed from an independent 20A circuit then the total load is less than 20A.
What change to be made to make this change of use NEC compliant?
Thank you.
Thank you.
