Electrical/Mechanical continuity
sharan
Is welding a 3/4" ss pipe to a post to route wiring considered to be electrically/mechanically continuous (NEC 300.10)?
It is about as continuous as you can get but as another poster mentioned stands a good chance of not meeting code requirements if you are running single conductors inside the pipe. In any case, a pipe is not a legal raceway, so it does not matter much if you weld it or not.
