electrical motor working space
mtache
New member
What are the NEC working space requirements for a 460VAC, 3 phase, electrical motor? The motor is belt-driving a piece of machinery.
Take a look at 110.26.
IMO, if you can honestly say you would never need to work on it energized, there is no working space requirement.
110.26 (A) Working Space. Working space for equipment operating at 600 volts, nominal, or less to ground and likely to require examination, adjustment, servicing, or maintenance while energized ...
BTW, this is not an unusual situation. many machines are built where you cannot work on a lot of things very comfortably.
I have never seen a "working space" for motors in the code book. However, make sure the moving parts are guarded, you have easy access to the motor connection box and you allow space for proper ventilation.
