The local AHJ (Miami-Dade County Bldg Dept) has determined that an existing electrical panel (120/208V, 3PH, 100A) that is adjacent to a dock - is in violation because it does not meet 'flood design' criteria according to a FEMA document (FEMA 348 - Protecting Building Utilities From Flood Damage - Nov 1999). I believe the AHJ may be erroneously using this FEMA document (which applies to building support structures) to our 'free-standing' electrical installation. This panel does not even feed any buildings; it feeds lighting, receptacles, and pumps on the dock. The AHJ has instructed that we either need to raise this panel to the flood design level (about 10' above ground - not practical) or we need to make it 'watertight' - which I am looking into ways of achieving this (I have found "explosion-proof" panels from Appleton which are also listed as 'watertight').
Is the AHJ off-base on this? What are the actual requirements for this type of panel?
Thank you!
Thank you!
