I have a job where there is no electrical room nearby an elevator machine room, from the main switchboard I run a feeder to an electrical panel installed inside elevator machine room, this panel has only (2) breaker to serve (2) elevator motors. The elevator inspector came out and said:
1) Can't install electrical panel inside elevator room - Does any one know or has a copy of section inside elevator about this rule?
2) He requests to have (2) separate feeds from other location goes into elevator machine to serve the (2) elevators, can't bring one feed to the panel (located inside elevator machine) even each elevator is protected by its own breaker in the panel.
Thanks a lot!
Anbm
Thanks a lot!
Anbm
